Date/Time: Sun, 19 Jan 2025 06:14:14 +0000
RAYS
View Count: 649
[2018-03-26 11:37:52] |
User725605 - Posts: 60 |
I am able to successfully place a horizontal RAY on any chart time frame. I have multiple chart time frames on several separate monitors. I would like to know if a RAY placed on a specific time frame can be extended across all charts on all monitors. Thank you. |
[2018-03-26 14:14:35] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
