Date/Time: Sun, 19 Jan 2025 06:15:39 +0000
Custom Studies Disappearance
View Count: 667
[2018-03-26 10:31:41] |
User787778 - Posts: 142 |
I updated from version 1697 to 1725 and it appears that a large number of my custom studies have been deleted. I attached screen shots of my Control Bars (before and after), my Custom Button Study (before and after), and the list of available Custom Studies (before and after). I have re installed version 1697 and this has rectified the matter. |
Private File |
[2018-03-26 14:05:51] |
Exit from Sierra Chart and go to your desktop and run Sierra Chart using the icon and make sure you do not use the one with _64.
