Date/Time: Sun, 24 Nov 2024 06:58:55 +0000
Pivot Point - show only value labels?
View Count: 1488
[2013-10-02 21:29:37]
User14266 - Posts: 225
I am using the Pivot Points-Daily study. I have the value labels showing; this is what I like. My question....Is there a way to remove the pivot point lines from the chart? All I want to see is the value label of the current day pivot points. I find that the lines are unnecessary and clutter the chart.
I have tried changing the color of the lines to match the background, but in turn that also changes the color of the value label.
Thanks.
Date Time Of Last Edit: 2013-10-02 21:30:03
[2013-10-02 21:32:52]
I forgot one thing, I have the value labels showing in the Values Scale.
[2013-10-03 16:20:21]
mkata - Posts: 103
You can set your draw style to "Text". This will remove the pivot lines and still leave the highlight color in the values scale.
[2013-10-03 16:40:34]
Thank you mkata. Perfect!
