Date/Time: Sun, 19 Jan 2025 06:10:52 +0000
no real time data for clk18
View Count: 771
[2018-03-26 00:07:47]
jackdaddy - Posts: 10
trying to trouble shoot this myself but very difficult to setup and navigate. i am on free trial with the free trial data feed. . Also the chart does not move in real time i have to disconnect and reconnect to get 10 min delayed data please help, Thank You
Date Time Of Last Edit: 2018-03-26 00:58:46
[2018-03-26 02:07:53]
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#UnderstandingAccessingDataFromCME
[2018-03-26 11:43:35]
I have an unfounded TD Ameritrade account. In the setup instructions one part says it does not work and another says must be funded 500? But I have purchased sc full come data both give me delay.
Thank you
[2018-03-26 14:03:11]
You do need at least 500 USD in the TD Ameritrade account. We authorized your Sierra Chart account for now to receive the real-time data until the end of this month.
You should begin to receive the real-time CME data in about five minutes.
Date Time Of Last Edit: 2018-03-26 14:03:34
[2018-03-26 22:49:03]
Awesome, everything working great today. since i have not funded a broker i wanted to make sure td is a good choice as far as sc integration goes, if not please recommend a tried and true broker for sc. thank you very much
[2018-03-27 00:28:12]
It is fine just to use TD Ameritrade to accommodate the CME funded trading account requirement but otherwise it is not a broker we would normally recommend.
[2018-03-27 01:01:14]
Sorry for dragging this on but what broker do you recommend?
i will only be trading futures and want t enter orders through sc, Also i want to completely avoid any compatibility issue i will be with sc for a long long time. thank you for youre patience
[2018-03-27 04:36:19]
We cannot recommend specific brokers but you could use a broker that supports CTS. Refer to:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php
We recommend the CTS low-cost connection model, documented on that page, since you are already using the Sierra Chart Exchange Data Feed.
Date Time Of Last Edit: 2018-03-27 04:36:57
