Date/Time: Sun, 19 Jan 2025 06:37:59 +0000
GSP Bridge process not running
View Count: 771
[2018-03-25 20:40:08] |
OrderFlow - Posts: 26 |
Lately I seem to have a problem connecting to Rithmic data, Sunday evening only, on one of my machines - meanwhile it connects fine on another of my machines. Not sure where the issue is coming from - I notice the bridge process is not running but not sure if that is a symptom of the data connection issue or the cause. Rithmic Trading | Port for executable: 55020 | 2018-03-25 16:34:00 Listening socket (976). Port 55020 | Closed. | 2018-03-25 16:34:00 Rithmic Trading | Starting server: C:\SierraChart TT\Rim\DTCBridge.exe | 2018-03-25 16:34:00 Rithmic Trading | Bridge process is not running! | 2018-03-25 16:34:02 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55020 | 2018-03-25 16:34:02 DTC Client socket (19) | Creating socket. | 2018-03-25 16:34:02 DTC Client socket (19) | Connecting to IP: 127.0.0.1. | 2018-03-25 16:34:02 DTC Client socket (19) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-25 16:34:03 * DTC Client socket (19) | Initiating close of socket by core. | 2018-03-25 16:34:03 DTC Client socket (19) | Closed. | 2018-03-25 16:34:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-25 16:34:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-25 16:34:03 Rithmic Trading | Disconnected. | 2018-03-25 16:34:03 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-25 16:34:03 Date Time Of Last Edit: 2018-03-25 20:42:07
[2018-03-26 00:23:17] |
Any suggestions?
[2018-03-26 04:00:24] |
The Message Log is incomplete. We need to see the entire Message Log: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
