Date/Time: Sun, 19 Jan 2025 06:37:16 +0000
Stop
View Count: 1617
[2018-03-25 04:29:53]
User651753 - Posts: 77
Could some one please share how to disable the pop up box " order and postion" every time it run a backtest
I like viewing trade on the chart and feel like the extra pop up just get in the way
[2018-03-25 07:16:00]
It sounds like maybe this option is enabled:
Global Trade Settings Windows: Open Trade Orders Window When Order is Completed (Global Settings >> General Trade Settings >> Notifications)
Or the one listed directly below it.
Date Time Of Last Edit: 2018-03-25 07:16:06
[2018-03-25 08:48:08]
thank for the fast reply. I am going to Global Settings >> General Trade Settings. however, I can't find the option to enable or disable it. ( have looked thought General 1,2,3,4)
this is the pop I am talking about https://imgur.com/a/21kos
[2018-03-25 14:49:38]
JoseyWales - Posts: 67
It sounds like you opened the "General Settings" and not the "General Trade Settings". Go to Menubar->Global Settings->And the first button in the right column should be General Trade Settings.
Or use the shortcut (Ctrl+Shift+G) to open the General Trade Settings dialog box.
And then check if either:
"Open Trade Orders Window When Order is Completed"
"Open Trade Orders Window When Order Is Filled"
is enabled. If so, disable them and see if the problem still occurs.
[2018-03-26 00:09:35]
thank you so much
