Date/Time: Sun, 19 Jan 2025 06:20:03 +0000
[Programming Help] - PositionData returns zero values
View Count: 811
[2018-03-24 17:31:13] |
User257964 - Posts: 6 |
Dear SC support, for some reason PositionData structure contains and returns zero values after opening any long/short position in any of my scripts. Even when trying the sample script scsf_TradingExample from the tradingsystem.cpp: if (TradingAllowed && sc.CrossOver(Last, SimpMovAvgSubgraph) == CROSS_FROM_BOTTOM && sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED) { Result = (int)sc.BuyEntry(NewOrder); //Result = sc.BuyOrder(NewOrder); //If there has been a successful order entry, then draw an arrow at the low of the bar. if (Result > 0) { r_BuyEntryInternalOrderID = NewOrder.InternalOrderID; SCString InternalOrderIDNumberString; InternalOrderIDNumberString.Format("BuyEntry Internal Order ID: %d", r_BuyEntryInternalOrderID); sc.AddMessageToLog(InternalOrderIDNumberString, 0); BuyEntrySubgraph[sc.Index] = sc.Low[sc.Index]; } } // When there is a long position AND the Last price is less than the price the Buy Entry was filled at minus Stop Value, OR there is a long position AND the Last price is greater than the price the Buy Entry was filled at plus the Target Value. else if (PositionData.PositionQuantity > 0 && (LastTradePrice <= PositionData.AveragePrice - StopValue.GetFloat() || LastTradePrice >= PositionData.AveragePrice + TargetValue.GetFloat())) { Result = (int)sc.BuyExit(NewOrder); //If there has been a successful order entry, then draw an arrow at the high of the bar. if (Result > 0) { BuyExitSubgraph[sc.Index] = sc.High[sc.Index]; } } which I copy and paste, the output is the same. sc.MaintainTradeStatisticsAndTradesData set on true. Please advise. Thank you |
[2018-03-24 21:11:20] |
Is this during live trading trading and what order type are you using?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-24 21:12:38
[2018-03-25 12:15:17] |
It is sim and order type SCT_ORDERTYPE_MARKET.
[2018-03-26 22:11:46] |
Make sure you call this function after the order has been submitted and filled: Automated Trading From an Advanced Custom Study: sc.GetTradePosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-27 14:40:23] |
Well, I copy & paste the sample script scsf_TradingExample from the tradingsystem.cpp and get zero values. Should there be any adjustments done?
