Date/Time: Sun, 19 Jan 2025 09:07:53 +0000
Multiline DRAWSTYLE_TRANSPARENT_CUSTOM_VALUE_AT_Y
View Count: 1045
[2018-03-24 10:00:29]
User79074 - Posts: 105
I need a way to add multiple lines to DRAWSTYLE_TRANSPARENT_CUSTOM_VALUE_AT_Y. Is there a way this can be achieved?
For example
"100
200"
[2018-03-24 11:19:33]
Yes just by adjusting the Y axis value. This is all. You need to read the documentation for that draw style.
[2018-03-25 13:45:04]
Doesn't work correctly if chart is scaled. Then the 2 numbers come apart and don't stay together consistently
[2018-03-28 00:34:32]
OK we will see what we can do. We would have to use an additional extra array on the subgraph to specify a text height offset as an integer index. So 1 would mean that the text is offset by the height of the text. This is the only way to make it reliable.
[2018-03-29 10:07:51]
That sounds reasonable to me. Thank you
[2018-03-29 18:02:46]
This is now released in version 1726 and is documented. Refer to the Draw Style documentation:
Chart Studies: Transparent Custom Value At Y (ACSIL: DRAWSTYLE_TRANSPARENT_CUSTOM_VALUE_AT_Y)
Date Time Of Last Edit: 2018-03-29 18:02:54
[2018-03-30 16:36:02]
Thank you!
