Date/Time: Sun, 19 Jan 2025 06:24:44 +0000
[User Discussion] - do not stay in draw mode?
View Count: 989
[2018-03-24 02:58:29] |
User255153 - Posts: 14 |
I do not want to stay in draw mode. After my every draw,pls put me in Hand mode. How can I do? |
[2018-03-24 08:32:38] |
JoseyWales - Posts: 67 |
Go to the Menubar->Global Settings->Tool Settings->General tab->After Single Tool Use Change To: Hand. I've also found that enabling another setting on this page "Double Click On Drawing Brings Up Drawing Properties" to be helpful. Chart Drawing Tools: General Tool Settings Also on the Chart Values tab if you enable "Always On When Chart Values Tool Selected" and set "Action When Other Tools Selected" to Always On When Using Other Tools, this will cause the cross-hair to be constantly enabled even when drawing tools. Maybe not something you're interested in but I thought I'd share it with you. Date Time Of Last Edit: 2018-03-24 08:52:40
[2018-03-26 10:09:34] |
"Double Click On Drawing Brings Up Drawing Properties"? after I change it, how to set to default properties?
[2018-03-26 15:11:28] |
You can change default tool properties from Menubar->Global Settings->Tool Configs->Choose which tool you wish to change.
Date Time Of Last Edit: 2018-03-26 15:11:57
