Date/Time: Sun, 19 Jan 2025 06:33:45 +0000
Replay- of trade simulation chart
View Count: 663
[2018-03-23 18:39:54] |
User228927 - Posts: 55 |
Try to do a simulation on a chart that has auto trade study on it. Why are trades not being listed on trade position log?
Attachment Deleted. Private File UploadImage.png / V - Attached On 2018-03-23 18:39:24 UTC - Size: 89.11 KB - 259 views |
[2018-03-23 21:06:49] |
You need to refer to the documentation for the particular window tabs you are looking at, here: Trading Information Windows This is clearly explained. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
