Date/Time: Tue, 15 Sep 2026 14:47:06 +0000
[Programming Help] - Line +/- from current price
View Count: 1597
[2018-03-23 12:58:46]
AKR - Posts: 542
how can I draw a line 10 ticks above and 10 ticks below the current price line?
[2018-03-23 16:07:41]
Ackin - Posts: 1865
32 bit sierra
Date Time Of Last Edit: 2018-03-23 19:02:14
attachmentLine to last.dll - Attached On 2018-03-23 16:07:00 UTC - Size: 73.5 KB - 464 views
imageline to last offset.png / V - Attached On 2018-03-23 16:07:08 UTC - Size: 13.78 KB - 412 views
[2018-03-26 12:31:52]
AKR - Posts: 542
thx! copied dll to my data folder, but study does not appear when I "add custom study".?
[2018-03-27 10:34:44]
AKR - Posts: 542
ah. 32 bit. thats the problem. but in 32 bit it said I need to update sierra to make it run. now I did update. now its 64 bit ;-)
[2018-03-27 14:14:56]
Ackin - Posts: 1865
no problem
64 bit file (Sierra chart ver 1709)
this kind of studies we have more free for download after free registration
Date Time Of Last Edit: 2019-09-06 17:01:11
attachmentLine to last_64.dll - Attached On 2018-03-27 14:13:16 UTC - Size: 86 KB - 493 views
[2020-01-16 13:13:03]
01110010 - Posts: 34
Sorry to bring up an old thread, but is it possible to get this study so the lines aren't projected backwards over all the old bars? But only forwards from the current price, as shown in example screenshot:
Unfortunately there were no customization options in the dll attached by @Ackin
imagecpl.png / V - Attached On 2020-01-16 13:12:47 UTC - Size: 17.25 KB - 428 views
[2020-01-16 13:28:26]
Ackin - Posts: 1865
I can extend it as an option in the settings. The study update will be on our forum.
contact link:
[2020-01-16 13:33:35]
I have registered on there, thank you.
[2020-01-16 13:47:57]
Where exactly on the forum will I find the update for this? just in the main 'free' bundle?
[2020-01-16 14:08:10]
Ackin - Posts: 1865
The "last update" folder and the dll file inside contains all the free studies.
I have unfinished things from summary window, crossover system and Icebergs. Then I'll look at your modification request in this study.
I'm almost non-stop there and not here. There also - You can write your comments or questions. You'll get the answer sooner.
[2020-02-20 17:07:56]
Hi, has this been addressed? I couldnt see any update on the forum yet.
[2020-02-20 19:36:41]
Ackin - Posts: 1865
FlyingLimousine)
You're right, I checked it and the study is really missing. I apologize ...I'll add it to the next update file (within a few days).
[2020-03-03 22:01:17]
Sorry to bother you, I couldnt find a way to contact you on the forum and didnt know where to post to ask a question, but it still seems there is no option to have the line only project forwards (e.g. like a ray, not a horizontal line). Thanks
[2020-03-03 22:44:17]
Ackin - Posts: 1865
"Sorry to bother you"
It's ok ...
"didnt know where to post to ask a question"
Directly to the study description...
Study: Line tick +- offset
It'll be in the morning update (in my time zone, in about 10 hours from now)
[2020-03-31 08:48:40]
Hi mate,
thanks for the update! I wondered if you could possibly make it so the price labels on the lines/rays appear on the right hand side, rather than the left.
Thank you!
[2020-03-31 23:07:24]
Ackin - Posts: 1865
Yes, I can. Give me a few days ... Then you can download in the CzSk forum.
(If someone had trouble signing up last week, please sign up again. There was a pause for extensive structure updates)
