Date/Time: Sun, 19 Jan 2025 06:09:24 +0000
sc.ChartTextFont is bold?
View Count: 723
[2018-03-23 07:34:48] |
User79074 - Posts: 105 |
Is there a method to detect not only sc.ChartTextFont, but if it is bold? Anyway to do this? Are can this be added? I need to match the the chart text font and therefore need to know the bold attribute.
Date Time Of Last Edit: 2018-03-23 07:37:24
[2018-03-23 16:57:40] |
We will have to add an ACSIL function to get these font parameters.
[2018-03-24 10:05:27] |
Thank you, that would be great to get it added.
