Date/Time: Sun, 24 Nov 2024 06:56:43 +0000
Delete All Lines/Drawings
View Count: 2838
[2013-10-02 17:28:46] |
tobi - Posts: 351 |
Is it possible to delete all lines/drawings in all open charts of a chartbook with only one command? Meaning, not having to go to each chart and using the command "Erase All Lines". |
[2013-10-02 18:07:04] |
No. You do need to go to each chart individually.
