Date/Time: Fri, 19 Apr 2024 13:03:22 +0000
Commissions
View Count: 1932
[2018-03-22 21:37:08] |
User952186 - Posts: 58 |
I only trade cryptocurrencies and maker/taker fees are important as they are higher than regular stock exchanges. For Bitmex: Maker Fee is -0.0250% Taker Fee is 0.0750% Long Funding Fee is 0.0143% Short Funding Fee is -0.0143% These are calculated 8 hours basis. How can I define these commission by using global settings>symbol settings>Additional>Round Turn Commission field? Is there a workaround? Thanks. |
[2018-04-27 08:08:41] |
Hi again, Is it possible to define commission rate as percentage? Thanks. |
[2018-04-27 23:24:04] |
No it is not. We will see about that later on in the year.
[2019-07-12 02:07:18] |
Leprickahn - Posts: 3 |
I agree it would definitely be nice to be able to calculate bitmex maker/taker commissions through Sierra Chart.
Date Time Of Last Edit: 2019-07-12 02:07:32
[2019-08-14 19:00:49] |
ILIM KIRGIZ - Posts: 187 |
Is there any update regarding % commission? It is very important for FX trading as most of the brokers such as LMAX are taking commissions abov nominal value of trades and it destroy P/L calculation badly. Thanks. |
[2019-08-19 08:21:33] |
User371879 - Posts: 4 |
it would definitely be nice to be able to calculate FX trading commissions through Sierra Chart
[2019-08-21 07:22:25] |
ARDAN - Posts: 66 |
I also trade via LMAX and they charge % commission on each buy and sell transaction. Sierra profit calculation is becoming useless without this feature. This feature would make life easier for LMAX traders. |
[2019-08-22 17:59:33] |
I open a trade with 20 ticks (2 pip stops away) which might have 2m$ position size which requires me to pay 200$ to open and close the position due to lmax fee. I do not see this in my P/L calculation and trade statistics. |
[2019-08-29 07:41:44] |
Dear support, What is required to be able to have such a crucial feature for an FX trader in high leveraged exchanges with significant commission %s? |
[2019-09-15 10:02:33] |
If you don't have a plan to add % commission, could you please let me know If we can do this via a custom study? Basically I need % commission to be included in all P/L calculations of my trades. Thanks. |
