Date/Time: Sun, 19 Jan 2025 06:34:35 +0000
Question about multiple connections with Sierra Chart Real Time Data Feed
View Count: 848
[2018-03-22 17:30:05] |
User315131 - Posts: 4 |
I'm considering trying out the Sierra Chart Real Time Data Feed.....it is mentioned in the pricing that for 10 real time symbols, it is $25 for the first connection, and $20 for the second connection. Does this apply to running multiple instances of Sierra Chart ? I am currently running 2 instances, but using the same connection (Rithmic). |
[2018-03-22 18:28:33] |
It depends. If you use the File >> New Instance function, then there is not a need to pay for a second connection. Refer to: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
