Date/Time: Sun, 19 Jan 2025 06:26:06 +0000
Disable New Bar at Session Start through ACSIL or a Global Setting
View Count: 846
[2018-03-22 17:17:43] |
JoseyWales - Posts: 67 |
Forex is a 24/5 market. I don't see the point in having New Bar At Session Start enabled on the Chart Settings dialog so I usually disable it, IF I remember to. This is most obvious on Renko charts, the bar before the session start time and the next bar appear to clash. So my question is: I have an ACSIL study that I call "Chart Formatter" that is applied to every new chart I create. Would you be able and willing to make the sc.NewBarAtSessionStart a Read/Write variable instead of it being Read-only? So that I could set it to false in my sc.SetDefaults or sc.Index == 0 block? ACSIL Interface Members - Variables and Arrays: sc.NewBarAtSessionStart |
[2018-03-24 01:15:46] |
Would you be able and willing to make the sc.NewBarAtSessionStart a Read/Write variable instead of it being Read-only? Yes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-24 01:16:13
[2018-03-24 08:19:48] |
I appreciate it as always.
