Date/Time: Sun, 24 Nov 2024 06:25:19 +0000
Disconnect
View Count: 1229
[2013-10-02 17:27:02] |
ElmStreetTrader - Posts: 48 |
I use ZenFire for data and if I don't trade in a 15 day period I get this message: "You have not placed an order within the last 15 days. The trading service you are using requires that you trade. Firstly, I pay ZenFire for data if I don't trade and secondly, I don't recall seeing that requirement anywhere. Is there any way to disable this? (Makes no difference whether I'm in live or simulated environment) Thanks |
[2013-10-03 07:33:18] |
There is no way to disable this and it is explained here: https://www.sierrachart.com/index.php?l=doc/Rithmic.php#TradingRequirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
