Date/Time: Thu, 28 Mar 2024 16:11:55 +0000
Custom Study: VwapBands
View Count: 1316
[2013-10-02 17:16:06] |
drak33 - Posts: 20 |
Hello, the custom study VwapBands contains parameter "Use Chart Settings Start Time instead of 0:00". If I switch it to "Yes", VWAP is calculated not from Start Time in Chart Settings, but from Evening Start. I think, it is not correct. My setup of Session Times in Chart Settings: 15:30:00-22:14:59 (main session), 22:30:00-15:29:59 (evening session). Times are in CET. VWAP is then calculated from 22:30:00 (after switching the parameter to "Yes"). I need to be calculated from 15:30:00. Is it possible? Many thanks, Dalibor |
[2013-10-02 17:21:23] |
In the case of when using the evening session times, the start time of the trading day is going to be the Evening Start Time. This is how it works in the financial markets. If you disable the evening session times, then the start time will be the Start Time.
[2019-08-26 00:03:19] |
Chad - Posts: 231 |
@SCE, is the source code for VwapBands study available? Apparently it used to be linked in this thread from the old SB: http://www.sierrachart.com/supportboard/showpost.php?p=132494&postcount=21
[2019-08-26 00:27:11] |
Ackin - Posts: 1863 |
CB12310 check this: https://www.sierrachart.com/AdditionalFiles/UserContributedACS_SourceCode/VwapBands.cpp |
