Date/Time: Sun, 19 Jan 2025 06:19:35 +0000
C.US.USAMK1814600
View Count: 639
[2018-03-22 09:19:47] |
User357295 - Posts: 76 |
Is there a way to get prices for CBOT TBond options with /64 format ? Currently the prices are on /32 format. Thanks |
[2018-03-23 02:22:45] |
Yes you can change the Price Display Format: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
