Date/Time: Sun, 24 Nov 2024 06:27:34 +0000
Cannot Change Users
View Count: 1409
[2013-10-02 16:29:13]
User80136 - Posts: 3
Since there are 2 trial users I cannot go from one account to the other ---------both using top step
tried the cancel
tried uninstalling then re installing and still cannot get it to work
thanks
[2013-10-02 16:56:31]
We are not fully understanding this support request.
Refer to the documentation here to Login with a different Sierra Chart account into Sierra Chart:
http://www.sierrachart.com/index.php?l=doc/LoginInstructions.php#DifferentAccountName
If you are having trouble connecting to CTS, provide the Message Log, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
We did locate what account you are using to login to Sierra Chart with and we have added some additional usage time to it.
Date Time Of Last Edit: 2013-10-02 16:57:32
