Date/Time: Sun, 19 Jan 2025 03:36:07 +0000
"Trading System-Study Subgraph Crossover" executes trades randomly in apparent error
View Count: 643
[2018-03-21 15:12:05] |
WilliamA - Posts: 26 |
Yesterday, in paper trading, I ran AutoTrade with your built-in "Trading System-Study Subgraph Crossover". It worked beautifully yesterday and again today trading SPY but not with ES when using what appear to be the exact same inputs. I'm attaching 4 PDF's showing the executions on the chart as well as the 3 study input screen shots. (Respectfully I did not use the suggested way to send screen shots since I'm not sure it can display the trades executed which I have marked or the study settings.) Do you have any suggestions? If necessary I'll pay for telephone support.
4-Errors AutoTrading ES.pdf - Attached On 2018-03-21 15:08:16 UTC - Size: 63.22 KB - 261 views |
[2018-03-21 17:52:22] |
We do not provide support for this even for an additional cost. Refer to: Automated Trading Management: Troubleshooting Automated Trading System Behavior If that trading study does not meet your requirements, then do not use it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
