Date/Time: Sun, 19 Jan 2025 03:10:23 +0000
Interactive Brokers AutoTrading problem and two questions
View Count: 947
[2018-03-21 13:33:44] |
WilliamA - Posts: 26 |
I'm experimenting with AutoTrading in paper trading mode. Worked fine all day yesterday. Last night I tried it to let it run semi-unattended. IB crashed. That is their TWS platform completely exited/disappeared for unknown reasons. I discovered the crash hours later. There had been no trades executed as a result. Q1: Is there an audible alert provided, either by default or that I can turn on when IB crashes in the future please? Q2: SC documentation said SC can support server-side AutoTrading. Does that mean I can opt to send entire AutoTrading instructions to IB such that even if the IB platform on my PC crashes, their server retains and executes AutoTrading instructions? |
[2018-03-21 17:55:12] |
Maybe the Trader Workstation automatically logged off? 1. Yes. You need to use this alert setting: General Settings Window: Server Connection Lost Alert (Global Settings >> General Settings >> Alerts >> Other Alerts) 2. We do not know what you are referring to here. In any case something like this is not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
