Date/Time: Sun, 19 Jan 2025 03:30:55 +0000
Set times for historical charts
View Count: 587
[2018-03-21 13:13:31] |
User509820 - Posts: 69 |
Hi, I use historical charts for daily and long term charts. With futures the times open and close at certain times. When using historical charts they are just calculating the 24hrs in a day which is not how futures calculate they're days. Is there a way for the platform to know open and closes without manually putting them in there? And with historical charts I can manually input and times.
[2018-03-21 18:09:35] |
Refer to this page: Historical Chart Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
