Date/Time: Fri, 11 Sep 2026 16:26:14 +0000
Issue getting accurate sc.ActiveToolYValue value on right click
View Count: 1142
[2018-03-21 04:05:09]
User474198 - Posts: 5
I have an issue where I am trying to right click on a specific price then select a menu button (placed in the menu by the custom study) that will feed the price to the custom study. The Y values I am getting from sc.ActiveToolYValue are not the prices i am clicking on (i have the hand tool selected). In the below code, the message log is printing a Y value that is consistently several points lower on the chart than where I clicked. On the NQ contract, the Y value is consistently 2.25 points lower than where i clicked, on YM contract the Y value is consistently 7 points lower, etc. The tick value in Chart Settings is correct, and the sc.ActiveToolIndex is returning the correct value.
Why isn't this code returning the price that I right click on? Thanks for the assistance.
// Section 2 - Do data processing here
  int& menuButton = sc.GetPersistentInt(1);
  if(sc.Index == 0)
    sc.Subgraph[0][sc.Index] = sc.Index;
    sc.PlaceACSChartShortcutMenuItemsAtTopOfMenu = true;
    sc.ReceivePointerEvents = ACS_RECEIVE_POINTER_EVENTS_ALWAYS;
    //Add Menu shortcuts
    if (menuButton <= 0) menuButton = sc.AddACSChartShortcutMenuItem(sc.ChartNumber, "Test_Y_Price");
    if (menuButton < 0) sc.AddMessageToLog("Adding Menu Item failed", 1);
    return;
  if (sc.LastCallToFunction)
    sc.RemoveACSChartShortcutMenuItem(sc.ChartNumber, menuButton);
    return;
  if(sc.MenuEventID != 0)
    SCString y;
    if(sc.MenuEventID == menuButton)
      y.Format("The Y value is: %f and the X value is: %d",sc.ActiveToolYValue,sc.ActiveToolIndex);
      sc.AddMessageToLog(y,0);
[2018-03-21 04:58:09]
We think we know the reason. This probably is fixed. Update to the latest prerelease:
Date Time Of Last Edit: 2018-03-21 07:44:09
[2018-03-21 15:40:33]
The update corrected the problem, thank you for the quick assistance.
