Date/Time: Sun, 24 Nov 2024 06:38:41 +0000
Error Connecting to Base Barchart Data Feed
View Count: 1308
[2013-10-02 15:57:31] |
bol0802par501 - Posts: 3 |
Dear Sirs: Starting around noon yesterday (10-01-13), my SierraChart experienced problem connecting to the Base Barchart Data Feed. The log claimed "Error connecting socket: Window error code 10061: No connection could be made because the target machine actively refused it." I contacted Barchart support and was told: "Barchart.com Realtime 9:42 AM (58 minutes ago) to me Mr. Hsiao, I have had numerous Sierra Chart users with the same problem. Please contact them. Regards, Richard " I am sending the log to you to look at and see what was the problem. Thank you. Sincerely, Shyh-Lin Hsiao |
[2013-10-02 16:12:01] |
Go to Global Settings >> Data/Trade Service Settings. Set the Connection Port to 7500. Press OK. Select File >> Connect to Data Feed.
