Date/Time: Sun, 19 Jan 2025 06:36:46 +0000
CountDown Timer from another timeframe chart, price overlay?
View Count: 1393
[2018-03-20 17:36:54] |
User252419 - Posts: 235 |
How can I see the CountDown Timer of the 5 min chart in a 1 min chart? I've tried Study/Price Overlay and Text Display for Study and Text Display for Study from Chart but it doesn't work. Thank you Date Time Of Last Edit: 2018-03-20 17:45:10
[2018-03-26 14:54:08] |
In which variable is it stored the value of the current CountDown Timer of a chart? I want to see a 1 min countdown timer value in a spreadsheet or in some place in order to work a condition based on it. Thank you |
[2018-03-28 01:07:56] |
You need to set the Display Value Only Input with the Countdown Timer study to Yes to do this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-28 01:08:15
