Date/Time: Sun, 19 Jan 2025 03:22:12 +0000
[User Discussion] - The Number Calculated Value: a myth or a legendary tool unknown from the majority...
View Count: 1162
[2018-03-20 13:47:10]
s291117 - Posts: 28
Hello Support,
I would like to know if you could explain here or in a video the Number Calculated Value Indicator and especially the Max Delta, the Min Delta, the Finish and the Finish %.
I did not find in the help section any content that could to understand how to use these tools in real time while trading.
Yes, i went to: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#s300
and found something about the finish.. Finish Ask Volume Bid Volume Difference Percent (Finish AskVol BidVol Diff %)
But i really do not get into it.
What is the edge that one can find with that ??
Could you send me a clear definition of these tools please ?
Could you hire someone that would realise qualitative videos to show detailled information about specific tools of sierrachart, help user to get into the parameters for each of them, special configurations, set-ups, etc.
That would be nice. I do believe that.. you have the money for that.
The aim would be, in a marvellous and perfect world, .. to understand what to read first, in which order, which priority to observ on a daily basis to be able to read interesting reversals situations,
reading inside the candle.
Attached are some screenshots.
Could you tell me if the analysis i have written inside are correct ?
There are nearly no videos on Youtube and this is really weird especially when it deal to trade futures volumes.
Thanks for your support.
imageYMM8_200318_Footprint_10Mn_Reversal_Down.png / V - Attached On 2018-03-20 13:39:19 UTC - Size: 275.48 KB - 372 views
imageYMM8_200318_Footprint_10Mn_Reversal_Up.png / V - Attached On 2018-03-20 13:39:44 UTC - Size: 304.29 KB - 350 views
imageThe Finish.png / V - Attached On 2018-03-20 13:46:54 UTC - Size: 143.42 KB - 365 views
[2018-03-20 18:42:46]
binaryduke - Posts: 375
You may find our video on Delta useful:
https://youtu.be/aOwci8d2P5E
[2018-03-21 01:02:25]
NumbersBars - Posts: 141
If you are interested in learning about "Finish" and related stuffs, as far as I know Discovery Trading Group has some related materials. (go google it, don't ask me for URL, otherwise, I will mark you as 'user discussion' also). But again, you have to understand their methodology in order to apply it properly. DTG guys are pretty solid. They don't use Sierra, but same concept applies if you put a little bit more effort to understand it. (I am no affiliate to them, just trying to help here).
Date Time Of Last Edit: 2018-03-21 01:03:01
