Date/Time: Sun, 24 Nov 2024 06:55:56 +0000
Downloaded version 1029 and can't connect to barchart realtime data
View Count: 1223
[2013-10-02 14:25:35] |
User628 - Posts: 18 |
Called barchart and they said other people are also having the same problem. Help!
[2013-10-02 15:18:09] |
Sierra Chart - Max - Posts: 5730 |
Please post a copy of the Message Log following the steps here: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support |
[2013-10-02 16:17:35] |
This is not related to version 1029 or any particular version. We have done some additional testing. Go to Global Settings >> Data/Trade Service Settings. Set the Connection Port to 7500. Press OK. Select File >> Connect to Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
