Date/Time: Sun, 19 Jan 2025 03:32:29 +0000
What file(s) are these settings saved to?
View Count: 563
[2018-03-19 20:03:56] |
Jeff M - Posts: 24 |
I was wondering what file(s) the General Settings is saved to as well as the Control Bar Customizations and any Global type settings. I have had to do a clean install of Sierra into a new folder when I changed brokers to get it to work and I would prefer not to have to go back and re-customize my sounds, Control Bar, etc. it's a ton of work. Any help would be greatly appreciated! I couldn't find any information on what files all this information is saved to when searching for it on the Sierra website.
[2018-03-19 20:10:54] |
This is explained here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
