Date/Time: Sun, 19 Jan 2025 03:12:26 +0000
duplicate chart
View Count: 1233
[2018-03-19 15:30:22] |
User635423 - Posts: 51 |
I do not want to duplicate the chart within the same chartbook. I would like the same chart in a different chartbook. Is it possible to do this? Thanks |
[2018-03-19 16:57:14] |
User701453 - Posts: 176 |
Yes, All you have to do is select "Duplicate Chart to Chartbook".
[2018-03-19 19:45:21] |
Yes this is supported. Use this menu command for this: Chart Menu: Duplicate Chart To Chartbook (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
