Date/Time: Sun, 19 Jan 2025 03:01:12 +0000
[User Discussion] - Renko Brick Graph Draw Type + 1/Price Study
View Count: 951
[2018-03-19 14:27:52]
User34124 - Posts: 279
Hi please check this. When the study gets applied to a Renko graph, the bricks go very very thin and had to distinguish. Then any attempts to modify the subgraph settings in the study keep resetting back to default. This defeats the premise of the study if the graph cannot be visualised.
Thanks.
[2018-03-20 18:15:52]
After applying the 1 Divided by Price study, be sure that on the Subgraphs tab, the Graph Draw Type at the top of that tab is set to Renko Bricks or Renko Bricks with Wicks (whichever you are using).
You can find the documentation on this here:
Chart Studies: Subgraphs Tab >> Graph Draw Type
[2018-03-21 11:54:03]
Yes, that was done already
