Date/Time: Sun, 19 Jan 2025 03:32:59 +0000
Can't figure out how to fix this data difference
View Count: 671
[2018-03-19 08:15:24] |
User19165 - Posts: 346 |
The DAX just rolled last week. Today I notice that I can't seem to get the right low to match on two separate charts. I tried to delete data and reload on the 60min and it came back the same. All my other charts show the low was 12318, but this 60m shows the low was 12310. Any ideas?
[2018-03-19 20:00:01] |
Refer to this section here to see what particular contract month you are looking at for those chart bars: Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-19 22:58:06] |
OK, I have figured out the reason. Both charts are set to auto rollover on a date back adjusted basis. The difference is one chart has a defined day and evening session, whereas the other chart does not and instead combines the day and evening into a single session. Rollover occurs after the day session has closed. So one chart will rollover in its defined evening session, the other rolls over at the start of the next day.
