Date/Time: Wed, 27 Nov 2024 02:26:10 +0000
[User Discussion] - Flex Renko
View Count: 1676
[2013-10-02 13:09:26] |
crazybears - Posts: 314 |
Hi could be useful to have an option fixing the minimun HL of a bar before a ne one is formed . I mena if i set 5 ticks as BoxSize , i like to have a new bar formed after the HL of the bar is real 5. now a new bar is formed and have a boxsize of 5 when really has been traded up to only 1 price. thanks |
[2013-10-06 13:32:40] |
Hi :) up |
[2013-11-08 13:52:20] |
User31703 - Posts: 16 |
Does the 5 renko get choppy like this? http://www.sierrachart.com/image.php?l=1383918638511.png This is not even as bad as it was today right after non-farm payroll news. I had to "reload and recalculate" over and over to make the chart readable. see the post by User31703 titled "5 renko can't handle the moves" Date Time Of Last Edit: 2013-11-08 13:53:43
[2013-11-09 00:55:07] |
vegasfoster - Posts: 444 |
Have you tried checking this box? http://screencast.com/t/SCUYFlQRiOq
[2014-07-24 20:38:08] |
Hi :) up I tried apply renko chart enhanced on flex renko chart to reduce the number of bars that are formed only by 1 tick one can see it if select candlestick bar in chart settings. If possible having option to set the number of ticks when a bar change direction and after that bar the minimum number of ticks before a bar is formed . |
