Date/Time: Sun, 19 Jan 2025 03:12:29 +0000
Charts lost with Update 1717
View Count: 828
[2018-03-19 04:27:02] |
User35670 - Posts: 2 |
I recently updated SC to version 1717 and to my dismay all my Charts within each individual Chartbook had disappeared with the exception of the default chart which was the last chart appearing before SC was closed. Years of work putting indicators and setups had disappeared in a moment. All gone. Is there a way to get back all my charts before the 1717 update?
[2018-03-19 04:32:39] |
You did not lose anything. Refer to: Missing Files After Upgrading Software Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
