Date/Time: Sun, 19 Jan 2025 03:31:04 +0000
Dom and Trade Chart
View Count: 773
[2018-03-18 22:51:06]
User180814 - Posts: 45
I am using a full Sierra Dom
1. For some reason every time I adjust an order I have to click on the order after the adjustment to lock in the change. How do I eliminate this feature?
2. When I want to create an order from the left side the dome I have to click on something that says trade after I left click. I want to get rid of this extra step and just be able to left click and then have the drop down options for the trade type. How do I eliminate the extra step of clicking on Trade?
3. ON the trade chart after I activate the trade chart I do not have drop downs on the chart for placing a trade. How do I make those trade options appear.
Thanks for your help on this Sierra.
Regards,
Marc
[2018-03-19 00:48:49]
1. Refer to this setting here:
http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#UseClickReleaseClickAdjust
2. We are not really sure what you are referring to. We recommend following the instructions here to use the Chart/Trade DOM:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM
3. Refer to the instructions here:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#EnteringOrdersFromTheChart
Date Time Of Last Edit: 2018-03-19 00:49:25
