Date/Time: Sun, 19 Jan 2025 03:15:10 +0000
Price overlay to Numbers Bars chart
View Count: 1189
[2018-03-18 17:34:14] |
ticinotrader - Posts: 397 |
Dear Support, I would like to create a layout where the price bars of another chart are overlaid to a NumbersBars chart as you can see on the image below: http://www.sierrachart.com/image.php?Image=1521394138663.png I want to display the overlaid candles in the space between the bid/ask prints. Can you please let me know how can I decrease the candle widths - make them thinner to fit into the space between the bids/asks? I tried the reduce bar width option through the Chart menu, but it has no effect on the width of the candles - seemingly the width of the overlaid candles are controlled by the barwidth used for the Numbers Bars chart. Thank you. Date Time Of Last Edit: 2018-03-18 17:53:27
[2018-03-19 00:50:55] |
This is controlled with this particular setting: http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#CandlestickWidthPercentage If you want to change the setting for the individual chart, then refer to the instructions at the top of this page: http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
