Date/Time: Sun, 24 Nov 2024 06:38:03 +0000
possibility to interrupt study calculation
View Count: 1307
[2013-10-02 12:28:58] |
namlem - Posts: 94 |
Is it possible to interrupt/cancel calculation of Spreadsheet 'Study for Alert' started by Ctrl+Insert? if not, do you have plans to implement this? Thank you! |
[2013-10-02 17:24:37] |
No. This is not supported. There are no plans for this. It is not simple to implement this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
