Date/Time: Sun, 19 Jan 2025 03:35:49 +0000
Kagi Spreadsheet for trading
View Count: 1295
[2018-03-18 13:17:52] |
marty_nv - Posts: 85 |
In an attempt to build some spreadsheet for trading studies in basic Kagi environment, --I first put up a Kagi chart as main graph Attachment 1 --I note that no data appears, Attachment 2 --I add a study, study appears in column A instead of after the formula columns, ,Attachment 3 --IF more studies are added, they appear in formula columns instead of after formula columns Find attachment 4, simple chartbook. Documentation here: Kagi Chart indicates any time frame should work, preferably shorter. I have used .5 Range bar, new bar on range met. Thanks for your help to re-organize properly. |
Private File Private File Pat 180318-3 Basic Kagi add study Spreadsheet result.png / V - Attached On 2018-03-18 12:59:51 UTC - Size: 62.13 KB - 312 views 180319-1 Kg Re-con 180315.Cht - Attached On 2018-03-18 13:06:14 UTC - Size: 48.87 KB - 259 views |
[2018-03-18 14:28:43] |
Please disregard this request, somehow the "include in spreadsheet" box in Kagi was de-selected. My oversight.
Pat 180318-4 Kagi Solution.png / V - Attached On 2018-03-18 14:28:00 UTC - Size: 56.68 KB - 297 views |
[2018-03-19 00:22:59] |
OK understood.
