Date/Time: Sun, 19 Jan 2025 03:31:04 +0000
Bitfinex Market Depth Data Feed now Requires Prerelease 1719 or Higher
View Count: 1096
[2018-03-17 22:17:13] |
When using any Bitfinex crypto currency exchange symbol and you are looking at market depth data, you need to update to prerelease 1719 or higher in order to properly view the market depth. This is due to changes with market handling within Sierra Chart. To update, go to this page: Software Download If the Fast Update method does not work for you, then just simply download the installer directly from that page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
