Date/Time: Sun, 24 Nov 2024 06:20:10 +0000
equities / ETF data feed
View Count: 1643
[2013-10-02 12:26:11] |
SKY - Posts: 45 |
Hi looking for a reliable data feed for equities / ETF by reliable I refer data preciseness (including volume) can u pls indicate few names out of the supporting compatible feeds ? as I can see merely google finance supports equities but they are unfortunately are not known as a quality feed and it may cause us to fail on taking trading decisions. appreciate yr assistance on the above need tnx |
[2013-10-02 17:23:58] |
Have a look at IQ Feed: http://www.sierrachart.com/index.php?l=doc/DTNIQFeed.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-02 20:22:00] |
CarlRostron - Posts: 80 |
For end of day data what I do is programmatically download data from yahoo finance driven from an access database using VBA (you could do this with any language) write out the CSV file to my sc folder and then just open up these files from sierra charts. All data is free that way and you have access as to all of the instruments available on yahoo. :-) SC, would you have any problems with me selling this system from a commercial perspective? If so then I understand just thought it would ask first... |
[2013-10-02 23:12:27] |
You are most welcome to sell this.
