Date/Time: Sun, 19 Jan 2025 03:35:33 +0000
Bitfinex Market Depth Data Feed now Requires Prerelease 1719 or Higher
View Count: 589
[2018-03-17 22:16:54]
When using any Bitfinex crypto currency exchange symbol and you are looking at market depth data, you need to update to prerelease 1719 or higher in order to properly view the market depth.
This is due to changes with market handling within Sierra Chart.
To update, go to this page:
Software Download
If the Fast Update method does not work for you, then just simply download the installer directly from that page.
