Date/Time: Sun, 02 Feb 2025 19:51:44 +0000
Cancel Orders on Flat Position
View Count: 2227
[2018-03-17 19:49:05] |
User35525 - Posts: 182 |
I use NON-server OCO orders (because CTS doesn't allow server-side OCO with parent market orders), but I want to make sure I never, ever have working orders after I exit (even though I monitor Trade Orders and Positions >> Orders). Will Menu/M >> Orders >> Cancel Orders on Flat Position do what I need?: Basic Trading and the Trade Window: Main/C >> Menu >> Orders >> Cancel Orders on Flat Position (chart specific) Also, this trade menu option isn't saved with Menu/M >> Save Configuration, and so it must be re-enabled after restarting Sierra Chart. Date Time Of Last Edit: 2018-03-17 20:24:12
[2018-03-17 21:54:38] |
Will Menu/M >> Orders >> Cancel Orders on Flat Position do what I need?: You just need to use Cancel All before exiting: Trading Information Windows: Canceling All Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-02 18:09:39] |
User145424 - Posts: 11 |
This option does not remain enabled reliably even in the same session. Surely it is much safer to have this option saved if required than to disable it when the user doesn't expect it. I always have this option enabled but must remeber to do so or I get unexpected positions appearing. Having this option saved in the configuration would be very useful and for me, much safer.
[2019-10-02 19:53:50] |
It is saved in the Trade Window configuration and it may be changing precisely because you are changing the Trade Window configuration to a configuration which does not have it saved: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Or you are using Trade Window linking which is also causing it to get disabled from another Trade Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
