Date/Time: Sun, 19 Jan 2025 03:13:02 +0000
Swing indicator error?
View Count: 991
[2018-03-17 08:05:09]
EuropeanTrader - Posts: 290
Hi, please see attached. I don't know why I am seeing a swing high if there isn't any. Thank you
imageScreenHunter 1667.jpg / V - Attached On 2018-03-17 08:04:58 UTC - Size: 123.6 KB - 285 views
[2018-03-19 01:47:43]
Do you notice that highlighted indicator go away when you select Chart >> Recalculate?
The problem is related to the particular Price Display Format you are using. Change it to .00001 which it is by default.
Date Time Of Last Edit: 2018-03-19 01:54:39
