Date/Time: Thu, 23 Jan 2025 09:31:09 +0000
How to update to 64 bit
View Count: 2027
[2018-03-16 20:53:14] |
User807026 - Posts: 86 |
I am running 1713 32 bit and I go to Help>Download Current Version and it says it has downloaded current version. I then get the screen that asks if I want to let this software make changes to my computer and I click Yes. I then just get a blank screen and no install happens. I want to update to the 1717 64 bit. How do I do that?
[2018-03-16 22:12:19] |
Xfanman1 - Posts: 320 |
For now you can use the SierraChartFileDownloader.exe in your main SierraChart folder. It sounds like SC Support is working on a fix for this soon based on comments in another thread today. Scott |
[2018-03-16 22:59:16] |
Use this installer: https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe We also released version 1718 to resolve the issue and this issue clearly is some kind of Windows 10 bug. That is clear from our perspective. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-24 16:37:22] |
ganz - Posts: 1048 |
SC Support It is recommended to use the 64-bit version...
Use this installer:
So would you pls provide 64_bit-only installer in case it'll not takes a lot of time to release it?https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe Thnx. |
[2018-11-24 22:26:48] |
The installer will always be 32-bit and we see no reason for it to be 64-bit. But are you asking that you do not want the installer to install the 32-bit version of Sierra Chart?
[2018-11-25 04:42:57] |
SC Support The installer will always be 32-bit ...
imo, it's not follow your logic since you have recommended 64 bit but it's up to you. But are you asking that you do not want the installer to install the 32-bit version of Sierra Chart?
No. It's about pure 64 bit because I see no logic to have 32 bit part of wine on linux in order to run installer only since RHEL/CentOS and Debian 64 bit has no that crap.The fact is 2D graphics performance on wine 1.4.1 is far better compared to Win10 to drive some charts using SC. Looks like the well development apps and setups are in the past in most cases. Bad reality. Keep providing *.zip / mobile version to make it possible to solve this in other simple way. Date Time Of Last Edit: 2018-11-25 04:44:28
[2018-11-25 21:29:01] |
Okay so you are asking for the 64-bit installer for running on WINE. For now we just recommend using the zip installer.
