Date/Time: Sun, 19 Jan 2025 03:19:48 +0000
Link Drawing with different time scales
View Count: 1171
[2018-03-16 14:50:52] |
Rnn - Posts: 56 |
Hello, Is there an option to link drawing between different time scale charts? lets say I want the trendline of a 3 min chart to be seen on the 30 min, 1h and so on and with the exception for the studies for example if i draw line on a 3 min RSI without it duplicate to the 30 min RSI I tried linking but without success thank you |
[2018-03-16 18:46:09] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
