Date/Time: Sun, 19 Jan 2025 03:39:07 +0000
Is global scrolling possible?
View Count: 1549
[2018-03-16 11:50:10] |
patrader - Posts: 92 |
I'm familiar with the global cursor but was wondering if it was possible to have all charts automatically scroll to match the time/date of the cursor position in the active window?
[2018-03-16 18:33:41] |
Yes this can be done with the Synchronize Charts option: https://www.sierrachart.com/index.php?page=doc/Tools.html#SynchronizeCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
