Date/Time: Sun, 24 Nov 2024 06:33:32 +0000
Bid/Ask Volume Text Trehshold
View Count: 1526
[2013-10-02 09:44:00]
imdtrader - Posts: 26
Hello, I have a question on Bid/Ask Volume Text Threshold field in Numbers Bar study while using Text On Dominant Side Auction text coloring method.
I did not find this threshold documented in the Numbers Bar section of manual a thus have a question:
Is it possible to use Bid/Ask Volume Text Threshold to color the selected bid/ask levels with different color?
For example: If I put value 50 in the threshold, now Sierra just hides all the bid/ask that are below 50 (I see empty spaces in the numbers bar). I would like however to see the low numbers, but in some light color. Is this possible with current settings?
[2013-10-03 07:48:52]
It is documented.
Have a look at the Column # Compare Threshold (<1.0=%,>=1.0=Values): inputs:
https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#InputSettings
You will want to use this in combination with the Column # Background Coloring Method Input:
https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#BackgroundColoring
