Date/Time: Sun, 19 Jan 2025 03:08:32 +0000
data export
View Count: 615
[2018-03-15 17:43:47] |
User449734 - Posts: 5 |
Dear Support, is this possible to export data from the charts not in Min but 1h format and also with specific format of date/time and column names? Thanks! |
[2018-03-15 18:49:16] |
Some of this is supported. Refer to: Edit Menu: Edit >> Export Bar Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
