Date/Time: Sun, 19 Jan 2025 03:35:50 +0000
LMAX level 20 Data and Order flow Settings
View Count: 724
[2018-03-15 15:12:36] |
Giamsterdam - Posts: 33 |
Are there certain settings to make the LMAX tick data more effective with the Number Bars study? Would it be possible to use the Market Depth study as well with LMAX data? Cheers, Giacomo |
[2018-03-15 18:13:43] |
We do not understand what is meant by more effective. In regards to the second question, yes you can use the Market Depth Historical Graph study with LMAX data: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
