Date/Time: Mon, 27 Jan 2025 16:54:34 +0000
DEFAULT WORKSHEET WILL NOT LOAD
View Count: 1041
[2018-03-15 14:42:09] |
brando - Posts: 14 |
Did a system recovery and Sierra Charts reloaded except for Default Worksheets. Unable to fix from instructions in Resetting Sierra Chart To A Default State. Request remote assistance. Using version 1689 with old worksheets. Telephone number is 815-493-6105.
[2018-03-15 19:12:03] |
This is going to be a chargeable support request. Did you still want the help? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-15 20:17:03] |
Yes please
[2018-03-15 20:59:25] |
Sierra Chart - Max - Posts: 5780 |
We have started this ticket for you: https://www.sierrachart.com/UserControlPanel.php?page=SupportTickets&Ticket=1521147519539#ViewTicket Please respond to it with a good time to call. Sierra Chart Support |
[2018-03-15 21:40:34] |
It is 4:35 p.m. CDT. Now until 6:00 p.m. would be a good time or tomorrow from 11:00 a.m. until 3:00 p.m.
[2019-02-28 20:29:44] |
Did a system recovery and Sierra files were saved but I cannot reload it. I am using the old charts with default worksheet. Request phone assistance.
[2019-03-01 01:46:53] |
Do you still need to use version 1307 of Sierra Chart? That is getting quite old.
